Hi guys
I recently rooted my Wildfire S and installed CM7 which is running great, however there are some issues...
Firstly I can send SMS but not MMS when I try sending a MMS it says "Sending..." but then gives me the following error and doesn't send:
Sorry!
The application Messaging (process com.android.mms) has stopped unexpectedly. Please try again. Force Close
When I try and access MMS setting it also closes and I can't access SIM toolkit either???
It's a EUROPEAN GSM HTC Wildfire S running with the O2 network
Any ideas?
Thanks in advance
Sorry!
Any ideas?
Thanks in advance
