Root Force close problem
arnandtara
I'm using cm7 with all fixes and it's starting to force close a lot. I'm sure it's something simple, but does anyone have any ideas?
Did you use titanium backup to restore any of your apps? I've never had any force closes using cm7. If you used titanium, that's the issue.
