it started when i was texting a friend.
The messaging application had unexpected problems and had to close.
Then almsot every application didn't work, the same "unexpected error"
The most prominent in them was Twlauncher I guess.
Anyway, I have restarted it many times and each time it was different, sometimes other apps worked, other times other worked.
It seemed like something specific was causing it. for example out of the many times i restarted, maybe twice I had severe force close loops of Twlauncher and other app. I had to turn off the phone.
So after maybe 10 restarts or more suddenly it works, I tried to open the apps i suspected to cause this error and all is good for now.
Anyone have any idea?
*I have only downloaded mobile browser app and used it.
