Root Force Closes?
Beatlesfan
So I rooted my inc using unrevoked 3 beta. I had upgraded to 2.2 using the leaked update.zip. I installed cyanogenmod, didn't like it, and did a nandroid backup restore to get back to sense. I then installed hydra kernel 1.15. I went back to the stock kernel thinking that that might be it, but to no avail. Now, after turning my phone on, the following screen pops up 5 or 6 times:
Anyone know what it is and how I can fix it? I'd be willing to totally wipe my phone and start new. (I can reinstall apps with titanium after I reroot).
Ok, I've determined that it has something to do with syncing my google contacts. I still don't know how to fix it though. Any ideas?
i can only verify that i am using the same Kernel and setup as you on my 2.2.. and it's running like a champ..I think your right,you need to investigate Gmail. If you are using Titanium Backup, have you tried to just reinstall that app from the Batch files??
