Root Force closing Das Bamf Sense 3.0 RC4
jennay22
I flashed a new rom today, Das Bamf Sense 3.0 RC4 and I'm really liking it. I also flashed the OTA MR2 radio. I backed up all my apps with Titanium backup before flashing and used it to restore. I'm now getting a bunch of "force closing" when I try to open the apps. Another thing is when I try to listen to iheartradio (after I uninstalled and installed again), I get a bunch of crackling which is pretty annoying. Are these common issues? Should I reflash radio and/or rom? If you have a recommendation of another Sense and Gingerbread rom, I'd love to hear it! I almost feel like I want to reboot in recovery and restore stock rom because of these issues :(. Please help:)
Did you restore system apps or data?
If so wipe and flash again and don't restore any system data
I did restore app + data, no system anything. I'll reflash.
Eta: should I do a back up in recovery or just wipe,wipe,wipe and reflash?
You could try rebooting in recovery and doing fix permissions. Also you may want to check the team bamf forums to see if anyone else has the issue. Sorry but I don't run sense roms so I've not tried out this one
Just wanted to update (for you Yeahha:)) I decided to install Das Bamf uber Bamf rom since apparently the sense 3.0 rc4 is no longer being worked on. I'm liking it, but the popping and crackling is still there, but only for the iheartradio app and really, only in the beginning of the broadcast. It's getting better and tolerable. I like this rom so I"m sticking with it. Glad I finally decided to root.
