LightShowJerk
Ight so it started with the web browser and then the play store and after a few minutes evrything i opened force closes excluding Facebook cause it force closes reguardless
Have you tried a factory reset?
What rom?
Backside
Open terminal emulator app and type:
su
fix_permissions
reboot
Nothing worked for me, I tried everything. like 20 diff roms and ports, sammyz can walk u thru firmware update method I'm sure if u ask him nicely, but I found that the easiest possible way for ZERO freezes or force closes is to flash kelsomod rom.
Its nothing lile cm7 but absolutely no errors its flawless
Ill be sure to try them once i get my computer working
Cm7 is awesome if u can get the om working without errors so thats deff a better choice, but if you are tight in time and patience then go with kelsos mod
Im not having any problems after i did the fix_permission thingy sammyz said to do but if i have any problems in the future and cm9 isnt out for our phones then ill do that
Ya sometimes it works sometimes it won't. Good to hear though congrats
