Help Force stop issue
DCFC79
Started today where my Galaxy S2 was telling me to force close some apps, I couldnt send a text as the process had to be stopped, I couldnt listen to music as the app i used (i tried 2 or 3 apps) had to be stopped and I couldnt access the play store as the play store had to be stopped. Wasnt just 1 occurance but 3 or 4 different instances.
And the other problem was my sd card decided to play up and couldnt access the music stored on it (am trying a second card I have to see if its the card). Yesterday it was fine, music would play, I could send texts and access the play store.
Anything I can do ?
It could be a bad card, or it could be bad memory in the phone. Or it could be too many apps running at once. It's not a "one fix for all" problem, so all we can do is guess. Someone has to have the phone in hand to check it.
Just trying a different card now, be a shame if the card is bad as its a 32gb and has done quite well.
Its not the card as get the same error, the app i use to play music is doubletwist.
The Force stop of apps seems to have stopped. The card is able to be read by a pc but not the double twist app so does that still mean a duff card ?
Thanks for your help Rubkat
Hi, just thought I would update the thread, the issue Id posted about has now decided to stop, still unsure what the actual problem was. Im considering replacing the phone and selling the SGS2.
