Root Ford Sync issue on KaosFroyo 37
Trumpup
So, I just Flashed to KaosFroyo V37 from White Widow. So far the Froyo seems to be much faster and smoother than WW. My only issue is that I cannot get Ford's Sync to pair with the phone on this ROM. It has worked on every 2.1 ROM that I have used. It gets to the point where you enter the PIN into the phone and then the connect process crashes. Any ideas?
I was able to solve this problem. Instead of having the phone discover Sync (as the manual instructs) make Sync discover the phone and use 0000 as your password.
