I'm really wanting to upgrade to JB but not at the risk of my Sync/Nav unit not reading and displaying my text messages. I have Sync version 3.1 not MFT.
Can I roll back to ICS if JB is incompatible with my car?
Monica
Hey, guys... I did the Jellybean update to my MAXX, and I too lost the ability to read texts via Sync. I have the "standard" original version of Sync in my 2010 Fusion. I was just on a chat with Ford, and they checked to see if there were any updates for my system, and they said no. They also told me that it wouldn't work with Gingerbread or ICS, but it of course did-- it was only after Jellybean that it stopped working. (What was even more worrying is that after specifically telling the guy that I have an Android phone, he asked me which version of iOS-- 6 or 6.1-- that I had on my phone. *Facepalm* Ford really needs to get their act together.)
I've been happy with the Sync functionality up until now. Everything worked great with my Droid X and then my Razr MAXX. This is really frustrating, however. I tired a factory reset of Sync, did the update (of which there really wasn't one), removed and re-paired my phone. No joy.![]()
Same issue. No text messaging on my 2012 Ford F150 after the upgrade.
Thanks for your helpful reply. It has nothing to do with being lazy. I can tell you it's a lot easier, and safer, to keep my eyes on the road, push one button and listen to the message while driving. I had that option prior to the upgrade. I'm behind the wheel for hours at at time and I get a lot of text messages. Some of them are actually important.The world will now cease to exist because we are too lazy to check txt messages when we aren't controlling 2 tons of steel in motion.![]()
I was really hoping this would work. But it didn't. Still not seeing text messages after the reset. Thanks for the suggestion though.Both mine and my wifes on both our new vehicles works just like it's supposed to, I have a 13 F150 and she has a 14 Escape, however I didn't pair with sync while on ICS, my/her phone had already upgraded to jb before I bought my/her truck.
Any of ya'll try doing a sync reset?
This procedure is for sync basic NOT my touch.
How to Perform a Master Reset | SYNC & SYNC with MyFord | Ford.com
I'll give it a try. How do I apply the Sync update?I have a 2012 F150 with Sync and a Maxx HD running Jelly Bean. I can tell Sync to read messages and it will do so. Although I have not needed it, have you tried applying the Sync update?
