format usb storage
rashmeet
hii....! i have s2 n it has a huge problem in it i connected the wire wid the laptop to download a song n it erased everythin n it only charges it does not work prperly n it give only one option erase everything
Welcome to the forums rashmeet :)
Sorry to hear about the issues you are having :(
When you connected it did any prompt you on the screen, or did you have the correct USB drivers installed? Lastly, did Kies prompt you to do anything...
Otherwise which version of the S2 do you have that way i can properly assist you...I.E. Which carrier do you have and which version of android is it running?
Thanks for joining!
Does your songs and what's on your sd card show up on your phone? Or does it show nothing there as well?
Welcome to AF! Hope you enjoy your stay here. :ciao:
