Help Formatting MicroSD Card?
markfm
Member
I've got a new Samsung Pro 64GB.
I plan to use it for audio and video files, plus storing a backup from titanium. Ive already used SDfix on the G3.
Is there an app for Windows Vista that could do the original formatting and let me bulk shovel some Audio files onto it? Am I better off putting it into the g3, use some android app to format it, then transfer files via USB?
Thanks!
I just plugged it into my phone, and did a factory reset while choosing to erase the SD as well. Seems to be working fine.
Had the same formatting issue.
CURE was easier than "Factory Resetting": Just erase SD card. Afterwards, I was able to copy my hard-drive-saved MUSIC folder from my PC to the phone's card. THAT easy....Slow process but very easy. Had at least 32 gigs of music and got the 64 gig micro SD card cheap. Try Meritline...
