Forums 2.0
Just tried it, couldn't log in and had to downgrade.
<br>
<br> Yes still on 4.4.2
I will test that for you and PM you a new build ASAP. Might not be until Monday but might be later tonight 🙂
  • Like
Reactions: Rob
Ok here we go-
Timeline doesn't update although My Stuff does.
Example My Stuff shows I just posted in this thread a few seconds ago, but in Timeline it still shows 50 minutes as the last post. Manual refresh doesn't help.
Ok here we go-
<br> Timeline doesn't update although My Stuff does.
<br> Example My Stuff shows I just posted in this thread a few seconds ago, but in Timeline it still shows 50 minutes as the last post. Manual refresh doesn't help.
Change the filter from New topics to most recent.
  • Like
Reactions: Rob
Still no search? How does one find channels for apps they don't have or devices they don't own?
One minor thing, when I tap the bars on the left it shows my username with a "New Member" tag.
Also tapping a user's name in a post doesn't bring up their profile as one would expect. I don't recall if this was ever working, is it supposed to or planned for later?
One minor thing, when I tap the bars on the left it shows my username with a 'New Member' tag.
<br> Also tapping a user's name in a post doesn't bring up their profile as one would expect. I don't recall if this was ever working, is it supposed to or planned for later?
Yeah, currently not finished. We are in discussion on how we will integrate user profiles. We may bring back the header on the my stuff tab.
Same here.. 'New member' tags. Layout is looking better tho!
Another thing not a biggie, but worth considering: we've lost the 'all threads' option in the feed filter, just have recent, trending, & new
This started after a few days..
Uninstalled, rebooted, reinstalled, all good.
My bad.. Should've waited longer
An issue that has been present from the start of the 1st Forums app ever posted.. When posting a msg,  direct translation of post content is correct. But when editing the post and hitting Send, symbols get reprinted a a Weird assed structure of '&& (something something)'.. You can see it in this post I made to help someone earlier..
Standard AF account sign-in.. Not Google or Fbook
I will be testing this today yet... Most likely a little bug overlooked. If you signed in with Fbook, then we would have some serious issues, since I never added that feature 🤣
Investigating a paragraph issue that is kind of related to this so will look at this code too. Thanks!
Noticing that links can not be seen in the dark/blackout settings.. I thought @psionandy was pranking me with long spaces & commas in his repiy until I opened it up in browser. Just FYI
