Forums for Android™
New update posted to the original post and updated what changed and bugs, etc.
Here is a short overview:
  • Added support for spoilers
  • Improvements to formatting images in main body of content
  • Fixed bug where toolbar buttons did not work when toolbar was collapsed
  • Fixed favoriting issue related to the star toggle
  • Fixed crash involving certain devices at sign in
  • Fixed crash involving lower SDKs when opening reply/new post window
  • Fixed sign out of account (deletes all user data for security reasons)
  • Fixed token refreshing (bug that was not refreshing correctly due to multi-threading)
Didn't get the attach when editing my last post. Acted like it would.
Hey mang, @ stevealbright .. The location of the cursor WHEN Reply or editing to a post is off like 3 spaces.
Trying to use camera in toolbar below causes F/C
.. And also unable to edit other posts in threads in which I am the op.
Only gives the Report option
Still can't edit my own posts in the app.
When in a thread there is an "Edit Thread" option in the 3-dot menu but it takes me to the first post in the thread and it appears that I can edit the OP's post although I haven't actually tried to do so.
The Device forums/channels have some issues ...
Motorola Droid Turbo 2 is correctly present
Motorola Droid Turbo is missing
Motorola Moro G 1st Generation is correctly present
All other Motorola Moto G, X, and Z are missing
The screenshot of the favorites shows a problem with the current labels ...
... Thom
Just a short note that I just pushed an update to the Play Store that is just a patch. If you are having issues you can update with this file attached but otherwise, you can just wait to get the update.
I have a bunch of new improvements coming but needed to get this patch out to accommodate some needed server side changes. I also plan on catching up on responses needed too... been slacking with that but will be scanning the thread at some point today to take notes and/or answer any outstanding questions. Next update I will be updating the original post as well.
I installed the copy from Play Store. It failed during load. Message said ... Keeps Stopping.
Uninstalled and reinstalled and the problem disappeared.
... Thom
Installed fine from the Play Store.
App needs thread navigation in the tool bar and jump to first unread.
When I go to a thread, it often opens to the OP or the top of the last page.
When it opens to OP, I have to scroll all the way down to the bottom of the really long page to get to navigation so I can get to the last page.
I still have some clean-up to get finished and some more testing before I upload a new build to the Play Store... but this version attached is pretty stable. Major change is the timeline has a FILTER BAR... yay.
I also fixed a bunch of other minor things that I will update the OP with later. It won't be until late tonight or early morning so I figured you guys would want to test... and break of course :)
looking better, Mang!
App just keeps crashing when I try to open it. I'd love to send a bug report bug can't get the app to open.
When it wasn't crashing, the timeline hardly refreshed and still can't access PM's
I don't know if this is the right place for this, but is this really necessary? This is on the web page, not the app.
I get it, I can "remove ads with VIP" - but come on already. This seems a little excessive.
Is it me, or has the activity on AF dropped off the  edge of a cliff since the rebuild? I know I'm not the only one who noticed this..
And I can't access any of my PM's from the app
