OK guys, I have seen several threads in various handset forums on this but I can't seem to make any of the suggestions work.
As the title suggests I "just" want to forward an email BCC to a group in my contacts.
If I just select forward in the email itself I can get the BCC box up but can't get a group to show up there.
If I go into contacts and select the group I can send them an email ok but it is, of course, blank. I can find no way to attach/insert the contents of the email that I want to send (as in outlook where you can attach another email).
I'm using GMail BTW so I find it hard to believe that two apps by Google cannot integrate well enough to do such a simple job
Does anyone know a way to achieve this?
Or, does it work in the stock Email app or another 3rd party app?
Regards
Clive
Regards
Clive
