Help Forwarding Texts to PC
jthomas06
I was wondering if anyone knew a way to have text messages from the thunderbolt pop up on a PC monitor and then to reply to those texts from the computer?
Thanks!
Thanks!
There are apps in Market which address this.
By the way, I changed the prefix on your post to "Support," as you are not offering a tip, which is what the "Tips, Tricks and Tutorials" prefix is for. ;)
Go into the text message app, press the menu key, select settings, then go down and check "show e-mail address" under Recipient List Settings. Then you can send text messages to e-mail addresses.
Dennis
