found something intresting in leak v1 build
AndroidFantic
so I found the build number and some other things and ill. post the build file of what all I found
# For Eclair project build property customization
# For FOTA bug report
ro.error.receiver.system.apps=com.android.updater
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=ERD79
ro.build.display.id=ERD79
ro.build.version.incremental=134869
ro.build.version.sdk=7
ro.build.version.codename=REL
ro.build.version.release=2.1
ro.build.date=Thu Feb 11 22:36:17 CST 2010
ro.build.date.utc=1265898977
ro.build.type=user
ro.build.user=u70000
ro.build.host=Oven-X04
ro.build.tags=release-keys
ro.product.model=Eris
ro.product.brand=verizon
ro.product.name=htc_desirec
ro.product.device=desirec
ro.product.board=desirec
ro.product.cpu.abi=armeabi
ro.product.cpu.abi2=
ro.product.manufacturer=HTC
ro.product.locale.language=mdpi
ro.product.locale.region=
ro.wifi.channels=
ro.board.platform=msm7k
# ro.build.product is obsolete; use ro.product.device
ro.build.product=desirec
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=2.26.605.2 CL134869 release-keys
ro.build.changelist=134869
ro.build.modelid=
ro.product.ua=
ro.build.fingerprint=verizon/htc_desirec/desirec/desirec:2.1/ERD79/134869:user/release-keys
ro.product.version=2.26.605.2
keyguard.no_require_sim=1
# end build properties
# system.prop for device
rild.libpath=/system/lib/libhtc_ril.so
ro.ril.default.modem-type = 2
# ro.ril.hep = 1
# ro.ril.def.preferred.network = 4
ro.telephony.default_network = 4
wifi.interface = tiwlan0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 15
ro.ril.htcmaskw1.bitmask = 4294967295
ro.ril.htcmaskw1 = 268449905
ro.com.android.dataroaming = true
ro.com.google.locationfeatures = 1
# For SD storage insert notification sound
persist.service.mount.playsnd = 0
ro.cdma.data_retry_config = max_retries=infinite,0,0,60000,120000,480000,900000
ro.sf.lcd_density=160
# This file describes the media capabilities and profiles
# using system properties.
# Note: The property key and value has some length
# limit as defined by PROPERTY_KEY_MAX and
# PROPERTY_VALUE_MAX, respectively
# WARNING: We may not use system properties for specifying
# media capabilities and profiles in the future
ro.media.enc.file.format = 3gp,mp4
ro.media.enc.vid.codec = m4v,h263
ro.media.enc.vid.h263.width = 176,352
ro.media.enc.vid.h263.height = 144,288
ro.media.enc.vid.h263.bps = 64000,800000
ro.media.enc.vid.h263.fps = 1,30
ro.media.enc.vid.m4v.width = 176,352
ro.media.enc.vid.m4v.height = 144,288
ro.media.enc.vid.m4v.bps = 64000,800000
ro.media.enc.vid.m4v.fps = 1,30
#Welly_Fang_01/05/2010
ro.cdma.home.operator.numeric = 310012
ro.cdma.home.operator.alpha = Verizon
# Disable HTC checkin service.
ro.config.htc.nocheckin=1
# ADDITIONAL_BUILD_PROPERTIES
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.networklocation=1
ro.setupwizard.mode=DISABLED
ro.config.ringtone=Innovation.mp3
ro.config.notification_sound=Color.mp3
ro.config.alarm_alert=Light.mp3
ro.config.cal_notification=Vector.mp3
ro.config.msg_notification=Ascend.mp3
ro.setupwizard.mode=OPTIONAL
ro.com.google.clientidbase=android-verizon
ro.com.google.locationfeatures=1
ro.com.google.gmsversion=2.1_r1
net.bt.name=Android
ro.config.sync=yes
dalvik.vm.stack-trace-file=/data/anr/traces.txt
would others with the v3 and v2 mind posting their build info
Sent from my Eris using Tapatalk
This is from v3. The latest leak.
ro.build.id=ERD79
ro.build.version.incremental=165907
ro.build.date=Thu Apr 15 14:00:38 CST 2010
ro.build.date.utc=1271311238
ro.build.type=user
ro.build.host=Android-X03
ro.wifi.channels=
ro.build.description=2.36.605.1 CL165907 release-keys
ro.build.changelist=165907
ro.build.modelid=
ro.product.ua=
ro.build.fingerprint=verizon/htc_desirec/desirec/desirec:2.1/ERD79/165907:user/release-keys
ro.product.version=2.36.605.1
# ro.ril.hep = 1
net.bt.name=Android
ro.config.sync=yes
Well at least we know now that v1 and v3 are of the same build so that means that v2 should be to.
Im still looking through the system files and reading all info and notes about the leaks but i have yet to find anything about time bombs or when the release was scheduled and dont think that i would but i will get back and post all that i find that may be useful
