not really. try making a call when its pitch black. the phone will be lit, then go dim when you put it to your face, then light back up when you pull away. it is a proximity sensor in every sense of the word.They call it the 'Proximity Sensor' in the manual. This is sort of a mis-naming, since it clearly detects light. The proximity to your face, for sure, is accounted for by having the light blocked (and therefore the screen dim on a phone call, then light back up when you remove it from your face).
very strange debate..odd results
in a pitch black room if you make a call it will indeed stay lit until you cover the sensor
in a light room if you take a flashlight and cover the sensor it will NOT sense it. if you turn the flashlight off, it WILL sense it...
very strange...like a combo proximity/light sensor
Has anyone noticed another circle/diode below and to the right of the proximity sensor? You can only see it in direct sunlight. Not sure what that is and I don't think it mentions it in the manual.
AFAIK there are 2 sensors the ambient light sensor and the one he -vv- is talking about which is the proximity sensor
