I have upgraded my operating system to 2.2, downloaded Foxfi and tried to use it as a personal hotspot. It seems to come up alright but when you try to connect to it from another device it says the internet is not found. On my windows 7 laptop it says something about an invalid IP address and shows 'limited access' on the task bar.
I am surprised there is so little information regarding this problem using a google search.
I have tried everything I have found so far including rebooting the phone and adding 192.168.1.1 to the settings/wifi/advanced/gateway. I wonder if I check 'static IP' and enter my Ip address if that will help.
I read a lot of postive results with this unrooted app and am a little frustrated with not being able to get it to work.
I also wonder if Cspire has blocked it somehow.
Thanks for your thoughts
