Foyo killed my camera
mickeyjoe
Just installed the Android 2.2 (froyo) update on my desire. Now the camera will not work. If I try to start the camera or camcorder apps I just go back to the home screen. Barcode scanner will start but immediately show the error message
Sorry, the Android camera encountered a problem. You may need to restart the device.
I've tried restartig a few times, I even pulled the battery. But cannot get the camera working.
Is anyone having similar problems?
I have a widget called "Nexus One LED Flashlight" that works fine with the camera, well not at the same time which would be nice.
Widget is better than the flashlight application, who needs a dull torch. Toggling the light on and off is better.
Huh???
The HTC flashlight allows you to choose 3 brightness settings (of the LED) and it remembers your last setting the torch is just a pretty UI. It also has auto flash and SOS (a gimmick i know but in there anyway).
