I'll probably first do a reset...I see that most apps are stored on phone. and that after reset I can reinstall from my google acct. Should i move apps to sd card first? what would that accomplish. Will that save any config data stored in app?
Well what I did was reset back to factory settings. Of course doing that is booting up much better like it did originally. Obviously some app (that I probably didnt use at all wasnt playing nicely with the phone. Its going to take time to go through what I had and just add back apps I really actually used. If you move an app to sd card how does that effect the app. Does it run any different will any personal settings be saved that way should another reset be needed
