Root freezing when power on
thanks for the encouragement...
Flashed back to stock, and the "data enabled" isn't working and i now i cant get the internet with my phone... ( :confused: )
also showing a yellow hazard arrow when i power on under the SCHR720 screen
sounds like your a canidate for the " regarding Samsung 2.3.6 upgrade."
read read read;;;;;;; put your phone down and read the thread again and again..
then when you know what your doing. ask alot of questions on AF and then and only
then fix your phone,
o yea stop using odin till you know what to do!
sorry for your troubles but it lights up so it should be able to be fixed...
and when you do you'll love it that much more.
viperdink out!
viperdink out!
I've gotten the phone working again, MMS is working, ** doesnt seem to want to show my contacts but they are listed when i do a search for them, and they stay in the FAVORITES **
its running admiral beast again, and everything its copacetic
thanks for the advice though!
