Fresh 2.0 ROM
tweezy_
So Im using the Fresh 2.0 ROM, and its actually pretty good and all, but Im having one problem. When I keep my phone on for more than 2 hours and then make a call, I cant hear the person and vice versa .. any suggestions?
yes, Fresh is a CDMA ROM and since the OP is in Wisconsin that means he has a CDMA Hero. Flashing any ROM other than a CDMA ROM will result in a bricked phone. to correct the audio issue... flash the audio fix. http://link.geekfor.me/fresh20daud
I was making a point because this was in the GSM Hero forum and Jaffa said
Yep, use the villain Rom
And that rom ^ he is talking about is a gsm rom.. and since the op said fresh he has a cdma phone and flashing jaffas suggested rom would brick it..
which is exactly why I posted that bit of info as well as the link to fix the audio issue with Fresh 2.0d :D
I just hope the OP didn't try flashing the GSM ROM..
Wow. You answered someone's question from NEARLY three years ago? :)
Now that is what I call dedication. I reckon that it is most like that fellow has long moved onto a new handset by now, though. :p
