Yes, I have my GPS turned off. Some reason leaving GPS my battery would drain faster. I would only get 20 hrs with light usage and 10 hrs moderate usage. I didn't touch mobile network on LBS. I always leave that on.I've had it unplugged from the wall charger since about 12:30pm today, using it very lightly, made a quick 5 minute call also, did some tweeting. I unplugged it at 88%, its now at 74% (its now 5:30pm here), I never thorouhly tested the battery, I would just notice in maybe 30 mins time it would go down about 8% with light usage. I did noticed that you have your GPS turned off in your screenshots, do you turn off the mobile network for LBS too?
Today the battery seems to be a bit better based on what I already told you about it going from 88 to 74% in 5 hours, I'll test it out some more, is Cell Stanby time ok to be at 40%? this always seems to be the highest percentage most of the time
That's a good sign you getting better batter life.
This the way I understand so far about Cell standby. Correct me if I wrong if someone with more experience. Cell standby is would be between 10% - 50% depends on how you used your phone. The more you use the phone, the Cell standby will be less and more the phone is on standby not being used it will be higher. That how I see on my phone.
