Fresh stable having two problems
-l3x-
Member
I have been using the new Fresh Stable ROM for about 2 weeks. Everything seems to be likable except for the speed on certain time. The two times where i see my phone lag is when their is animation for the weather widget and two its always slow on the messaging app.
I wanted to see if anyone is having the same issues and if their are fixes and not necessarily "work arounds" for using a different messaging app.
Thank you
-L3x
Which fresh are you using, I've never heard of "stable", all fresh roms are described as being stable. You probably have either 2.1.1 or 2.1.2 which I believe is the newest.
Sent from my HERO200 using Tapatalk
Well I had that for awhile with no problems at all, I would factory wipe data/cache and flash it.
Well how do i do that. Will i lose root? Also, will this help the weather animation and messaging issue?
