Root FRF84b Themes/Themed ROMs
inssane
Android Expert
Alright, let's get this show on the road
THEMED ROMS:
Pete's Bugless 0.4 FRF84b themed (2.2) - Android Forums
Compatible THEMES:
http://androidforums.com/all-things-root-droid/109945-theme-xtheme-0-3-droid-x-froyo-2-2-frf84b-6-30-10-a.html
[Theme] 928Droid "Black Glass" 2.2 for Froyo - Update.zip - MetaMorph - Back to Stockl
[Theme] NexTheme for Bugless Beast V0.4 (6/29/10)
Start posting them and I will edit it for people.
I can't quite get KangaSaurus to work on it just yet - loads lock screen, everything is themed, then it reboots after SD Card load (sound off) - any advice in the meanwhile, let me know :)
What would make our lives a lot easier is if Android would come with a themeable interface that would allow app developers to simply insert a couple of lines of code that allows their app to follow whatever theme the default interface is using.
Then, devs could just theme the main OS interface, and all apps would follow suit....
I sure hops this becomes a reality before 3.0....
A few months back there was word from Koush that he was working on something like this... Haven't heard anything in a while, so not sure if he is still working on it or not...
Not exactly allowing the app devs to enter the code, but allowing easy theming and the ability to theme all apps including market ones...
Is there a theme I can apply for the BB 0.4 ROM that looks like Drotang by Manup? I really like the look of this theme.
Mmmmmmmmmmm....that DroTang/NexTang looks nice.
Right! Just saw JRummy's new Kangerade and the Nextang theme is one of the options. He must be psychic or he read my post haha. I wonder if it'll work with BB 0.4. I'm afraid to mess with it since it's running perfect right now.
Now I have to look for Kangerade, lol
Do you have a link? Does it work on this build?
