Help Fried Socket Charger?
aksel
Hey all! This morning I attempted a charge, and my SGS2 didn't recognize the socket charger. Tried other outlets without success, but had no problem charging via USB (so the cable isn't the problem). Question: is the little socket cube already burnt after two weeks of use? Has anyone else run into this?
Haven't run into it, but it's not surprising, they don't exactly spend lots of money on those. They should swap it out for you. I have several and used a mini>micro adapter on a BB charger and all seems to work well. If anything had to fail at least it was a cheap accessory. Good luck!
