Hi there my friend stream does not work properly.... actually even before the froyo update anyone has the same problem? does not sync all contacts with facebook, and sometimes no picture...
I had a similar problem when using 2.1 Eclair, no problem with linking contacts though only with the app not ever updating.
I searched numerous websites to fuind an answer but sadley they all suggested doing a hard reset which i eventually did and have had no problems with the app since.
Dont know if it will work for you but if you attempt a hard reset make sure you back up all of your contacts ETC.
