Friendly howdy and a quick question
alpha2k
Android Expert
Hey all.
Just thought I'd drop by from my s3 forums and say hey, how's it going and all that.
I frequent this forums now and then just never post.
Looks like things are still semi-active here, that's good to see.
I have a question, well actually 2....
1: Suggestions for a TW rom? It's a friend who has my old s2, and it's still rockin solid, going strong.
2: Any suggestions for a TB alternative that backs up apps+data? He wants a free solution to TB, that works. I bought TB so I only use it mainly, but was wondering if someone could suggest something.
Thanks for any suggestions, and nice to see this place is still hopping
I see you have gone to the S3, still waiting for it to come down in price here. For a great TW ROM, I am thinking project X is the one.
I used the free version of TB for backing up for a while before I decided to go with the pro version. If it is a cost issue, the free one worked well. If you put "app backup" in the play store, you will get a list of them.
Helium is kinda cool, but it requires a internet connection and also requires a pc side as well as the app.
TB free is good for backing up, but restore is a major pain in the butt, unless you wanna sit and hit install > done.....install > done for all your apps.
I was hoping there was a free version that did a 1 click install for all the apps, without interaction.
I'll look into ProjectX, but need a backup/install solution before I do anything.
Helium does not require a data connection, just tell it no when it asks you if you want to sync online
Ahh ok, cool, I might give that a try see how it works at least.
He's on a mac so it's gonna be hard to work with that I'm guessing.....that's why I was leaning to the phone side
