Help Friendstream Force Closing
My friendstream is force closing every time i try to open it. Any suggestions?
I had the same problem and found that by removing Twitter, I was able to get friendstream working again. I then reinstalled Twitter and so far, friendstream is still working.
Go to Manage Applications under Settings if you want to delete an app.
Have you tried just restarting your phone and seeing if that works first?
I've restarted the phone a few times. This has been going on for a while.
The only twitter apps I see are the ones that came with the phone. I don't see a way to delete these.
Oh yeah, totally forgot that it only works with Peep.
Well, I don't know what to tell you, other than maybe try a different social network aggregation widget? I heard socialite from the LG Ally works amazing (You will have to find the APK for it though)
Anyone know of a fix for this friendstream problem? It happened literally out of no where... I didn't install anything new..didn't change any settings.. just tried refreshing the friend stream widget and it didn't load. When I opened up the actual app, it just force closed.
Sent from my HTC Incredible using Tapatalk
I read on another forum that clearing the cache from SETTINGS>APPLICATIONS works...it worked for me, but not completely...I can now open up Friendstream and it doesn't force close, but theres no updates on the home screen???
