from 1 phone 2 another
  • Start date Start date
A
Android Question
Guest
I have a LG lucid that has all of my contacts in it but it is not an active ph. and would like to transfer my contacts to the Ph. I am using now LG Optimus dynamic how do I do this ?
Are your contacts not synced with your Google account? That's the easiest way, as they will automagically show up on your new phone when you sign into your Google account.
If not you can export contacts from your lucid and I assume you can use the same method to import them into your dynamic.
Brian706, Im not quite sure about google and sync, the phone (lg lucid) I am trying to get the contacts off of doesn't have a carrier and the other phone (lg optimus dynamic) is a straight talk phone (I think). I am not normally electronically challenged (:stupid: ) so I don't want to "play" around with ''trying" to do this or that and am not finding instructions on how to use google syn app. Anymore directions you can point me in ? Greatly appreciated in advance. :)
