Root From 596 to 602.. Process?
DatacomGuy
Is there a "how to" or process for upgrading from .596 to .602?
Will it require a wipe, go to Froyo, then flash .602? Or is there an update that can be flashed over..
If you haven't done anything to the system files (renamed/removed/frozen), then take the OTA and then re-root.
