R Ray305 Well-Known Member Nov 24, 2012 #1 Can you move the data of games (GTA 3, Asphalt 7, etc.) into the external sd card and still have them work?
Matix2600 Lurker Nov 24, 2012 #2 I would like to know also. I'm trying to setup link2sd to free up some space
R Ray305 Well-Known Member Nov 24, 2012 #3 If it's possible than I would love to use my 8gb SD card for the high end games.
Gman9831 I'm no Senior Nov 24, 2012 #5 Only way so far http://androidforums.com/lg-motion-4g/624910-found-how-move-apps-sd-card.html#post5017743
R Ray305 Well-Known Member Nov 24, 2012 #6 Gman9831 said: Only way so far http://androidforums.com/lg-motion-4g/624910-found-how-move-apps-sd-card.html#post5017743 Click to expand... Thank you so much, I followed the tutorial and the app works perfectly!
