Please note that all data will be deleted from the HTC EVO 4G as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
Turn the power off. If your HTC EVO 4G is frozen, pull the battery out and reinsert it
Hold the Volume Down button
Press and release the Power button
You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
Select Clear Storage by pressing the Volume Down button
Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC EVO 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
