Root Front keylights will not shut down
joselaz
Member
I'm running samurai ROM. Have had it for a while now. But today the front keylights just simply won't shut down, even when the screen is off. The settings say that the key lights should always be off, which is my normal setting, but they still stay on.
Nope, but I uninstalled the application LG Notifications, and reinstalled it. That did the trick. Using the application again and it's working just how it should work. Thank you.
I had a similar issue from installing this app here. When I uninstalled it I forgot to disable it first in the Accessibility menu so my key lights acted up afterwards. I had to install it again then disable it in Accessibility menu and then I was able to uninstall it with no issues.
Im having the same issue , i never installed that LG app, and still my key lights wont shut off, other suggestions?
