Froyo 2.2 Update Flash Beta )\(100% working)
Tugdaturtle
Google Has not Fixed the issue of the adobe Flash 10.1 for driod atm but they will so in the mean time Use this Beta one that works 100%. I have this on my phone So if you want it follow my instructions.(only works for 2.2 Update)
Download Instructions:
QR Code:
img.php
Click Here to Download Mega upload Link
Ver. 10.1.61.68
Or
img.php
Ver. 10.1.72.7
Click here to download
Just download it on your PC. Connect your USB to your Comp and Phone and place the download file into your phone. Then install and Enjoy adobe Flash 10.1 Beta
Thanks Tugdaturtle
I've tried installing it using appinstaller and it won't install. I've redownloaded the file twice with the same result. Any ideas?
Make sure you have this program on your phone to explore files in your phone. Its called ES File Explorer
chart
Click here to go to website for download on pc
Once you do that download the Flash apk file onto your comp. then plug in your usb to your computer and your phone then mount it and then place the file in a folder name Downloads and then once its in there unmount , then open ES File Explorer and find the folder Downloads and then install the flash then reboot phone then your flash should work
need anymore help let me know
p.s. when you are looking for it in es file explorer it should look like /sdcard/downloads/
QR Code:
img.php
Thanks Tugdaturtle
This version seems to be 10.1.61.68
The version downloadable at:com.adobe.flashplayer-3.apk
seems to be 10.1.72.7
Can anyone verify which version is currently recommended?
--D.
