Help Froyo 2.2 Update For Motorola Droid Please Help
I have the original Mototrola Droid and I want to update it to Froyo 2.2 but I have no idea how. PLEASE HELP ME!!!:confused:
Welcome to the forums, breanna13!
Stock Froyo? You can try to go to settings>aboutphone>systemupdates. See if that pulls the update. Are you sure you're not on froyo now?
As far as I know, that was an OTA update a couple of years ago, so it'd be worth trying this:
Menu
Settings
about phone
system updates
I hope it pushes to you! If that doesn't work, you may need to visit Motorola's website and see if it's available for download.
I tried to do it through my settings but it said my system was updated. And Im positive that Im not on Froyo yet. Is there another way?
Yes I believe Im rooted with Universal Androot
OK so if you are rooted with a custom recovery or if any system files have been altered as a result of root activities, you will not be able to receive over the air (OTA) updates. So you can update by flashing a stock, rooted ROM for your device if you do in fact have a custom recovery. Or you can flash an sbf to unroot the phone and return to a fully stock configuration at which point you could receive OTA updates again.
The only wildcard on flashing your way forward is that you are so far behind in your current OS version that there MAY be certain radio or bootloader requirements as you move forward. I am not an expert on this phone so I'm not sure if that condition exists in this case or not. Hopefully an OG Droid expert can chime in to suggest the best path.
I undid the root on the app just now and the update still wont so in my settings
Wow, never heard of an unroot button, you guys have cool tools for that phone. So I'm not sure what that does but evidently it doesn't reflash stock which is what you need. So I'm still of the belief that you'll need to flash an sbf stock configuration to the phone. That'll bring it back to true stock at which point updates should be accepted. Being non-savvy on the Moto scene, I'd wonder if you can just flash the most recent sbf and be done with it OR if you need to flash the sbf for the OS you are currently running, then update via OTA's. I would assume the prior rather than the latter but I'm just not positive.
And how do I do this flash sbf configuration
Actually, there was a harder but easier (i know, i know) way to restore being able to take updates. It involved modifying the build.prop file, IIRC.
BREANNA, this method will erase all your data, so only do this if you're sure you don't care about it, or do not mind starting from scratch again. Otherwise, give me a day too find the correct method to allow you to get the OTA.
Do you know if you are using a custom ROM on the phone?
No I am not using a custom Rom and I just factory reset my phone. It wont let me reprogram it myself so I'll call costumer service tommorrow. And my carrier is Page Plus do you think that has something to do with it?
Might want to wait to see what johngalt digs up although I'm surprised you wouldn't need root to modify the build.prop
Since you've factory reset your phone, you'd probably be best off just flashing an SBF for the DROID. Do you have the A855 model?
I was trying to find info on how to fix it without factory reset, but now that you've already done it it is probably going to be easier to just flash it yourself.
Yeah, but before she performed the factory reset, she had that one click root tool - she could just as easily re-root the phone as she unrooted.
__________
I just thought of something - could it be b/c it is PagePlus - that's why she's not getting FroYo? My DROID was through VZW, and we received those updates OTA....perhaps PagePlus never put out the FroYo update?
I am pretty sure I have the FroYo SBF for the DROID, but I am loathe to link it b/c I don't know if a VZW schemed SBF will work on a PagePlus phone. That will require further research.
So can she just sbf to the most recent build or does she need to sbf what she's on now and then ota her way forward? Good point about the vzw sbf versus her phone, didn't think of that possible pitfall.
I'm not sure if it's Page Plus either before this I had the same phone and as soon as I activated it it told me I had an update and it let me go to 2.2
