Help Froyo and SD Card
akametro
Does anyone know how to install apps to the SD Card?
I recently updated my Epic 4G to Froyo and from what I understand, one of the features of Froyo is that it allows one to install apps to the SD Card. I've tried sorting through every setting or menu option to set this up, but I can't figure out how to do it. Thanks.
Here's what someone else told me, so I can't take credit.
settings > applications > manage applications
Click on an application and if the app allows you to move it then "move to sd" or whatever it says, will be illuminated.
It works!
Ive moved all my apps to the sd card and they all work perfectly.
Are you doing this in 2.2.1, or are you using App 2 SD free?
With the added feature of 2.2.1, not all apps can be moved to the SD card. Just wondering if App 2 SD allows you to move all apps?
