TheTrueSpin
I can't say I have any issues... everything just seems better. Actually, I have noticed that my phone seems a bit more eager to rotate the screen, but other than that all is well.
The compass seams a bit funky. I have to calibrate before each use.
Not that I know of... only checking manually now and then in the downloads tab on the market. I think I remember reading about an app that searches for updates but I may be lying![]()
Are you getting this issue in your home?... if so its due to the electromagnetism from all the devices you have in your home (tv, computers, etc).
Mine is the same, if you try it in a field or some place away from any electrical device you will probably see a more accurate reading.
App Update Notifier in the Market. HTH
Anyone else having signal problems after upgrading to 2.2?
I rooted and then installed the official 2.2 Foyo but my signal is constantly dropping to nothing at all. Very frustrating
Hi, I hope you can help. I followed the procedure (given in this forum) to move all apps to sd, and it works very well. I was very happy with this until I started installing things like extended controls, etc.
The problem I get is that extended controls gets installed straight onto my sd card. I then get the widgets I want onto my screens. BUT, as soon as I hook the phone up to the pc in USB mode the widgets disappear and all I'm left with is a box which says problem with widget. When you go back into the widget bit extended controls isnt there. I then have to uninstall and reinstall, the build the widget again.
I've tried installing it, then moving onto phone and a few other things but cannot get it to work. Is there a way around this?????
Any clues on what I can do?
Seems to have fixed the problem for me. It's picked up the network straight away again.... Went out a few times today for well over 15mins.
You cant\shouldn't install widgets to the SD card for this very reason... It's not always available so not a good idea to do it.
it automatically installs them on to the SD card. is there a way round it?![]()
This is a limitation I'm afraid. Any apps which have background tasks running or things like widgets which are obviously always running, have to be left on the phone really. Whilst you can move them to the SD card, if the card disappears the app obviously fails.
When you connect your phone via USB in disk drive mode, the phone unmounts the SD card to give the PC access to it, so it effectively vanishes from the phone's perspective and any apps on it which are running will fail.
Yeah i know the limitations. The problem is that when I install anything it installs straight to the SD card not the phone.
Either I need to find a process to stop it installing onto the sd acrd, or I have to undo the "move all apps 2 sd" thing I did.
Anyone having trouble killing apps? Task killer says its closed them then if I check again a few mins later things are running again, like beeb player and radio. Also if I kill internet and go back into it it just takes me back to the page I last viewed and not my home page. Doing my head in!
I have had the same problem on an new unbranded unlocked HTC Desire A8181 purchased from Australia's Mobicity.
The phone arrived yesterday. I accepted the over-the-air update to Froyo about an hour after switching the new phone. Since then, it's been stuck in a constant re-boot cycle (every few minutes), with the "process system is not responding" error, and no wireless functions.
I have no desire to mess around with flashing the rom manually, so will have to send the phone back. Not sure if I want another one after this. :-(
