Hey Talderon, were you able to confirm if the file is legit?
Guys, the original link is legit ! I personally used it to install Froyo on my Nexus One. I am a first time poster because when I realized that the original link has been removed I figured this is the community that needs it and I registered in order to post it here for whoever needs it.
You can check the MD5...its the correct one.
That's sweet! Google don't even care that you install it manually! Also, it doesn't void your warranty either!
Android 2.2 Froyo on Nexus One Right Now Isn
Guys/gals,
We can't allow direct links to firmware downloads, legitimate or not. While the OS itself is open-source, the apps shipped with it are copyrighted by Google and hot-linking could be seen as facilitating distribution.
Hi Talderon,VERY slow download off a Romanian site... I call suspect...
edit: Wow, an hour to download 44.4MB? You can get it many other places faster... lol
Here is the MD5 info on the official one I used:
md5sum signed-passion-FRF50-from-ERE27.1e519a24.zip
5911bc88f5f9ddd25ed918a98f309ae6 signed-passion-FRF50-from-ERE27.1e519a24.zip
exit: Better yet, here is my DropBox link to download the file. You can use the above MD5 to verify, you can find the MD5 off the net to make sure I am not trying to cause problems.Let me know how the speeds are, if they are too slow, then I can upload to a mirror for sure.
http://dl.dropbox.com/u/3963477/signed-passion-FRF50-from-ERE27.1e519a24.zip[link removed due to copyright concerns]
Thanks!
Hi Talderon,
Could you confirm that the MD5 code you posted was from the update taken directly from the Google servers? Ive seen a few mirrors that have the same checksum, just wanted to be 100% certain before I apply it to mine.
Thanks in advance
