Froyo MMS video resolution
I send lots of text video messages. Before the 2.2 update, the MMS capable video had a decent resolution up to 30 seconds. Since the update, the resolution on the MMS setting (or the low setting) is horrible and almost too grainy to be visible. Is there any workaround? I tried taking just a very short high res. video but it won't let me text it.
I'm not running the stock Froyo but there are High 30s, Low 30s and MMS (Low, 60s) settings for me. If you can't MMS the video it's probably too large. How large is the file?
I can MMS the low res videos, but the resolution is so bad that it's almost unwatchable. Pre-2.2, the resolution on the MMS low setting was much better, so I know it can be a little higher and still be MMS capable.
Even a 1 second video on high is blocked by MMS.
Anyone have thoughts on how to upgrade the MMS video abilities post Froyo? As said above, it was much better before the Froyo update.
