Ok, it's no secret that I'm a noob when it comes to this so please bear with me as I try to explain my concerns..
First off, since I was frantic in trying to get 2.2 on my vibrant, I successfully rooted and (flashed) a 2.2 install using the following link tutorial...
http://www.ithinkdiff.com/how-to-upgrade-samsung-galaxy-s-to-android-2-2-froyo-build-i9000xxjph-guide/#comments
The update was successfull however I no longer had any kind of signal (no 3g..no signal bars..just a blue circle with a line through it meaning no service)
Realizing that I just hid a dead end, I went here...
http://www.youtube.com/watch?v=AnY7P14JSWQ&feature=player_embedded#!
Downloaded the 512 pit file and also downloaded the T959UVJFD tar file and followed the instructions on the video and successfully reverted to stock.
Before I get into the meat and potatoes, I will go into my phone info..
Build number- ECLAIR (no numbers, just ECLAIR)
Kernal version- 2.6.29
Baseband version- T959UVJFD
Firmware version- 2.1 update 1
In reverting back to stock, I have noticed several apps missing that was installed during the last OTA update which was my initial ECLAIR..task manager/t-mobile tv (or something like that) just to name a couple.
Ok now for the questions...
First..since I essentially manually flashed (don't know if I'm using that term correctly) my current version of ECLAIR, do I have the correct version since I no longer have those apps that were included with the OTA ECLAIR?
And second..which is my main worry..
Will I be able to recieve the OTA FROYO update that is about to hit the airwaves here shortly?
As to date there is nuttn really wrong with my phone lol I just wanted to 2.2 FROYO...I just hope I didn't mess anything up.
If my answer reflects that i'm up the creek without a paddle...I will GLADLY pay someone in the St.Louis area to fix whatever I did
