Help frustrated and lost help please
tepajo
ok here is my story....my son cracked his screen...mom, being mrs. fixit, well ii got the screen, broke the housing, replaced the housing and screen. YAY it worked...then i did a restore on the phone and i had a power outage, so i went to searching...the phone is up and running (YES YAY ME) lol wrong! now the wifi doesn't work.... mrs. fixit it at it again....changed the wifi wire TWICE...it still doesn't work grrrrr and then i went to open the camera and it said camera failed....did a factory restore....one pic....camera fail....did an odin flash the back camera works front camera doesn't.....wifi still not working!!!!!!!!!! so any ideas????????????? cause i'm lost not....no clue what to do....anyone willing to help a girl out here (preferably nicely)
SGH-I337
VERSION 4.4.4
BASEBAND 1337UCUFNJ4
THANK YOU!!! Does it matter that the baseband aren't the same??? I'll try this and see what happens!!
Use the correct firmware variant for your device.
Be sure to remove the sim card before flashing as it will be wiped clean.You can put it back in when it done flashing.
You will have to do the updates to your current android version once your done.Just like when you get a new phone.
There is NOTHING in this phone....I've done several factory restores...the sim is in another phone....truly hoping this saves the day.....thank you
