ftm mode isnt available when using cwm, its built into the original recovery and causes problems with cwm
plus if you did a system update it would remove cwm anyway
if you want though i posted a link to the stock recovery, you can flash it manually just like you would cwm and then be able to use ftm again to use the zte update tool
right, i know, its all in the cwm thread i added stock recovery earlier today and you use the same instructions that are given for installing cwm on my post
no auto installer though sorry, too much work for something kinda pointless to me
anyway here you go http://androidforums.com/warp-sequent-all-things-root/669226-cwm-6-v-2b.html
Hey, junkie, is there a way u can make a flashable stock recovey zip. So well beable to download it to sd, and then flash it via cwm. To get back to ftm. And then use zte update tool to go back to stock rom?
just make a back up of stock rom and restore in cmw you will have stock rom and cmw no point of stock recovery more custome rom are being build and just going to get better
the stock rom is on the cwm page and i left instructions on how to use my auto installer program with it or any recovery for that matter, just replace my original cwm file in the auto installers "files" directory with the stock one, no real need to code a zip for it, if you can install cwm you can install the stock recovery
