fujezone smartab tp700 stuck on loading
i tried reset button but problem is same
Operating System:
Android 2.2 (Froyo)
Phone:
No
Processor:
VIA WM8505 400MHz
RAM:
256 MB
Internal storage:
2 GB
Card Slot:
TF Card slot
USB:
Yes
Display Size:
7 inch
Display Resolution:
800 x 480 pixels
Height:
199 mm
Width:
138 mm
Depth:
16 mm
Weight:
420 gms
Audio:
Ear phone connector
Wi-fi:
802.11 b/g
Secondary Camera:
0.3 MPplz help me s
I believe FujeZone is an Indian importer of cheap Chinese tech products.
And been what these things are, more than likely the software(ROM) in your device has become corrupted, because it's buggy, rendering it unbootable(bricked). Probably the only solution is to try and re-flash it yourself, if you can get hold of the appropriate ROM file and flashing software, however a more realistic option would be to return it to FujeZone for repair or replacement.
