Help Full Desire reset
D
Deleted User
Guest
is it possible to do a full reset? back to how it was out the box, including revert back to 1.6?
but have the option to restore all my settings and apps? i only want to do it because having had the phone 2 months or so i inly followed the standard bits on the phone now im getting more into ''customisation''
but i need the idea of being able to revert back and get all my apps back ??
thanks
Ben
Yeah sorta,first use my backup trial version to back everything on your phone,
MyBackup - Android app on AppBrain
then do a factory data reset,this will wipe everything on your phone memory but will keep whatever android version you are running at the mo,2.1 or 2.2.
To do a factory reset press menu > settings > sd & phone storage > factory data reset.
Then when you are finished restore everything back on your phone using my backup.
