full screen ID dispay - Neat rom
shenga
just recently installed Neat rom but cannot say I care for the fuull screen ID display. Is there a way to disable it ?
Full screen caller id doesnt come as standard in Neat as far as I know.
You must of flashed a mod for it.
You need to install /system/app/phone.apk back off the original ROM's zip file.
I did not flash anything other than Neat Rom.
Maybe I am mixing something up and perhaps it is not full screen caller ID but what is happening is : when i dial a contact that has a photo associated with is, upon dialing the photo becomes much larger and pixallated.
In this case, I'm not really sure whats happening. I didn't have this with Checkrom v6.
If you store your contacts on google, when you flash a new rom and sync, all your pictures will be pixelated.
you need to reassign all your contact pictures manually.
hi Hawker,
forgive if Im confusing things.
Yes, I do store all my contacts on Google.
The photos using Neat rom are fine.
Its when i press a contact that has a photo associated with it, the photo of that person zooms to almost full screen and thats when it becomes blured. With checkrom, the photo of the person remained in a "smallish" box and never went to "what I describe" as being almost full screen !
Apart from the photo blowing up, everything seems to be fine.
Contact pictures will be zoomed in when opening the contact's details. This is how it is in all ICS ROMs.
However, you need to reassign your contact photos manually, so that they are not pixelated. When you install a new ROM, it syncs your Google contacts, but Google store these pictures in a very low resolution. Reassigning all photos manually will replace your contact's photos in your phone's memory, and will be sharp again.
Aha, penny has dropped :D
I did not realise this was a generic feaure with all ICS roms. Neat has been my first ICS rom so had nothing to compare with.
I will do what you have suggested. Thanks for enlightening me..
