Root Full signal untill making call or attempting to activate - help!
Jimmy422
I needed to go back to my trusty OV after my Galaxy Reverb decided to die. But when I went back I noticed the MEID was gone. So I re-wrote it using QPST and QXDM but I have an odd problem now. When I go to make a call or activate the phone using the SSA app, the signal drops to zero and it gives me a no-signal error.
Attempting to activate results in an 06-07-5910 error.
What is going on and how can I fix it?
Follow the stickies on how to get your MSL code and the AAA code. If you don't see you AAA code, and you didn't write it down so it could be re-writin, then you no longer will be able to get data service.
