This is going to sound so noob - but when I wipe, I usually wipe Factory & Data and then Dalvik. Should I go through everything in the wipe menu? Or are these two things considered a full wipe? Thanks!
Those are the two things I consider a full wipe. I only wipe battery stats if my battery readings are going wonky. I've never wiped cache from Amon_Ra, but I do use Cache Cleaner NG.
if you are using "trackball optional" recovery now,theres an option to wipe cache,so id wipe that too. its not neccessary to wipe battery stats every time you flash.as a matter of fact, the "correct" procedure for wiping battery stats seems to differ depending on who you talk to.
i generally just charge fully,wipe stats,and if the battery level has dropped ill charge untill full again. some folks will do this a 2nd and even a 3ird time,but i dont have that much patience like metal,i dont do batt stats unless i think for some reason maybe its off,or doin somethin wierd.
Anybody who is going to wipe battery stats is better off with this free app instead - you don't have to waste time booting to Recovery. AppBrain Android market | Battery Calibration
Wipe sd:ext is only useful if you are switching from a 2.1 based ROM using apps2sd with a partitioned SD card - it wipes the apps off the partitioned ext3 partition on the SD card.
