spyder
Well, I just flashed CM7 v: 05142011
I set up an EXT partition 512/32(for Swap)
I AM BLOWN AWAY, I didn't think it would work as well as it is. I figured before I get it too nice and personalized test moving the DALVIK OVER also, that was a main goal. So, according to TIt BU, my Memory:
(Weird now since this flash I have 4 lines of memory info):
System ROM 178 (72 Free) - This was never there b4, and hasn't changed w/ any app addition or changes, it just is what it is I think
INTERNAL: 198 MB ( 180 FREE) !!!!
SD CARD: 7.45 (7.27 Free) no much on there yet, song/pic wise, 8G card, but 512 for a2sd and 32 for swap
SD CARD(a2sd): 479 MB (348 FREE)
All appears to be running fine.
I flashed DT's a2sd with the signed zip, right after flashing the rom. Now in the Applications options it still says "Move to SD" ? Since DT's method tricks the phone to thinking it's on the phone, so just don't hit that and all good.
Just thought I would post since it seems totally successful....
Keep u posted if there are problems. CM7 is NOT listed on DT's FB as a supported ROM, BUT I noticed that list was made B4 CM7 was done.
Good luck...take care...Jeff
