defTwitch
Member
Just a heads up.
I know a lot of people (including myself for a bit) have had some issues with their SD Card mounting correctly... especially when running GB roms.
Check out this link:
How To Set Up ADB/USB Drivers for Android Devices | TheUnlockr
I had luck with the 3rd Option
"III. (Optional) Reinstall Drivers (If they did not install properly in Section I or II)1. Download USBDeviev..."
I just deleted EVERYTHING it found for HTC, Android, etc... and when the phone reinstalled this time I'm good to go.
ADB works without an issue... and when I switch over to "disk drive" windows sees my card everytime.
Before doing that I had to use internet pass through trick (didn't always work for me)... or remove the sd card and pop back in.
